Next up will be to harvest the 55 mm ortho drivers from a pair of Yamaha YH-1's I recently acquired. They are going to be transplanted into DIY mahogany - constrained layer over-ear housings. The design concept I've settled on will allow the stack of wood rings and resilient material to be easily shuffled to experiment with different materials. So far I'm considering cork and silicone for the rings. I'll also be able to vary the position of the driver relative to the ear. Should be fun to see if I can surpass my modified HP-1's and see how they stack up against the Stax's. Watch for a new thread in the not to distant future.
Well here we go. I've collated, filtered, and ruled out a gazillion ideas floating around my cranium. The hardware has been ordered, so today was spent doing full size drawings. If I was at home I'd pattern route the components, but I'll xerox copies and adhere them to the stock and go at it with the apartment tool kit. I have ordered a drill press stand for a Dremel which will add the needed drilling precision.
