so_ein_pech
Well-Known Member
Yesterday I was the somewhat underwhelmed owner of a pair Citation 7.2 THX speakers that sounded way worse than they had any right to given their outlandish MSRP.
While I'm sure the whole THX system was impressive, the speakers had some quirks that made them pretty useless as stand-alone stereo speakers. Each box has two tweeters placed too close together to intentionally limit the horizontal dispersion. And, worse of all, they were crossover limited to 80(!)Hz because they were designed to be operated with some big ol' JBL 15" subwoofers. These are not small speakers, mind you.
The cabinets are a bit damaged and were ugly to begin with, so I decided to open them up and see what they are made of and if they were worth parting out.
I am now the proud owner of 4 each of British Made Double Magnet HexaTech Aluminium Voice Coil Morel MW-166 Woofers and HexaTech Aluminium Voice Coil Liquid Cooled Soft Dome MDT-30 (an EC Product) Tweeters! Ok so the tweeters have one edge sliced off of the faceplate so that they can be installed closer together and one tweeter is impacted, but they still make and sell replacement domes for a reasonable price.
Now I'm trying to figure out what to do with them. I was thinking maybe some kind of Morel Duet clone? This is a speaker that I had never heard of before today but is apparently very well respected. From my preliminary research tonight, it used a more efficient/expensive but similar tweeter, and used the same MW-166 drivers. I am hoping that @baco99 will chime in since he seems to be the Morel evangelist around here and had a thread about a similar project he worked on a few years back.
I also found a crossover someone designed on madisound for a MW-166/MDT-32S speaker system. Based on the datasheets on the MW-30, it's the same as the MW-32 but with a smaller faceplate. Apart from a different Fs, I can't spot a difference between the S and non-S variants. I don't see any info on cabinet specs that would go well with the crossover as designed. I assume it's a sealed box?
According to the Renaissance Audio website the Duet is partially transmission line loaded. I like the idea of transmission lines, having recently acquired a pair of Timeframe 600's. But this guy over here says that the Morel drivers are best in sealed enclosures. Maybe I should stick to that since I've never built a speaker cab before.
So... any thoughts or recommendations?
