Bob Chieldon
Both service manuals are available online for the M60/M65 and I have read that the M65 is basically the M60 with a few changes to make it less likely to Chernobyl if something does let go.
I noticed that the manual for the M60 gives a bias figure of around 110mV +-10mV across the emitter resistors when the class A function is activated whereas the manual for the M65 merely says "more than 20mV" from a baseline class AB bias of 10mV +-1mV.
What gives?
110mV gives about half an amp from each output transistor, of which there arethree four and so a total class A bias current of around 2 amps, which gets us roughly 20 watts (peak, if I've understood the calculation correctly I think) in class A. EDIT: I got that wrong, there are only two per polarity not three. I assume then the total bias current flowing is the sum of the positive and negative side emitter resistors, which would give 2 amps instead on one and our expected 20w. Am I right in thinking is a peak figure?
A bias which is acceptable by M65 service manual proscriptions of lets say, 25mV would give a class A region of about a watt, which would make the amp out of spec according to it's specifications, surely?
What gives?
