philseven
Hi,
I have Kenwood LS 990a speakers needing to refoam. I read about classe A technlogy for suspension ? (on LS 880a the same)
I found (in audio-heritage):
Speaking about 2 suspensions ? Someone know this technology ? i need special foam ?
Class A suspension is Kenwood's original technology. It uses two suspensions made of engineered plastic / polyamide fiber. Appropriate mechanical bias is applied even when it is stationary. , Repeat the push-pull operation in which one side shrinks when one side stretches.
This push-pull operation cancels the opposite non-linear distortion components of each other, and realizes the linear movement of the vibration version that can convert small signals into small amplitudes and large signals into large amplitudes.
Thanks
Philippe
Thanks
Philippe
