Exactly what they said. AB is typically used just because you can squeeze more power out of the same tubes while still getting good overall distortion performance.
These are a bit of a strange design. The output stage is actually a differential amp, or a long-tail pair setup. Usually you see this as the phase inverter and the output from that stage feeds into the output tubes or whatever happens to live between the inverter and output tubes. The lower tube is running in grounded grid configuration, and input is via the cathode. I can see how this works with triodes, or even with pentodes, but with UL I honestly don't know. Seems to me you'd have two signal inputs, one at the cathode and one at the screen, and I don't honestly know what that would look like at the output. I'd have to wonder exactly how equal but opposite those are working. Likely would depend significantly on how accurate the taps are on the transformer.
but anyway, this sort of output stage has to work in class A otherwise there would be a portion of the signal that is not reproduced at the cathode and you'd end up with this ugly output that is clipped both top and bottom.
