Op Amps are a subject that many think is nonsense. For A/AB Amps it would hold true as the Op Amp does a different thing. But Class D the Op Amps have a direct and critical effect to the sound.
Following is a reference from the net that gives you some reasons.
Op-amps with the same specified resistor values can sound different because their underlying electrical characteristics—such as gain-bandwidth product, slew rate, noise, and input impedance—vary significantly, causing them to interact differently with the surrounding circuit. While ideal circuit theory suggests only the ratio of feedback resistors matters, in practice, the internal design, component matching, and thermal behavior of the op-amp dictate its actual performance.
Here is a detailed breakdown of why this occurs:
1. Electrical Performance Variances
Slew Rate and Bandwidth: Different op-amps have varying speeds at which they can change their output voltage (slew rate) and how much gain they provide at different frequencies (GBW - Gain Bandwidth Product).
Input Impedance and Capacitance: The input stage of an op-amp can introduce frequency-dependent loading, which changes the behavior of the input filter in the circuit.
Common-Mode Rejection Ratio (CMRR): Variations in how well an op-amp rejects noise from both inputs (common-mode noise) can alter the sound, particularly at higher frequencies where CMRR falls off.
Output Loading: Op-amps may have difficulty driving low-impedance loads, resulting in distortion that differs between models.
2. Circuit-Level Interactions
Stability and Oscillation: An op-amp with different internal compensation might become unstable in a circuit designed for a different type, leading to inaudible, parasitic, or audible oscillation.
Negative Feedback Loop: While negative feedback linearizes behaviour, different op-amps respond differently to this, particularly in circuits that are not conservatively designed.
Power Supply Noise: Op-amps have different Power Supply Rejection Ratios (PSRR), meaning some are more susceptible to noise from the power source.
3. Non-Ideal Characteristics
Distortion Profiles: Different op-amps produce different types of distortion (harmonic distortion).
Manufacturing Differences: Even when bearing the same part number (e.g., 4580), different manufacturers may produce parts with slightly different specifications or internal structures.
Summary of Key Factors
Feature Impact on Sound
Slew Rate Faster = cleaner; Slower = warmer/softer
Input Impedance Higher = less loading of the source
GBW Higher = more feedback, less distortion
Output Loading Ability to drive low impedance without distorting
While some engineers argue that in well-designed circuits, the differences are minimal, audiophiles and musicians often find that replacing "stock" op-amps with different models changes the tonal quality, soundstage, and, in some cases, stability.
