Big_T
Member
What would, be the cleanest most pure way to reduce the output gain from my EAR 834P Phono stage (clone) from about 50db (seems to be the consensus on the output) to about 40db? So a reduction of about 10db.
I’m fine with adding a high quality volume pot at the output sections but was wondering if using a resistor or some other combination would be a more clean and pure way to reduce the output.
Also I already tried putting in 5751 tubes all three positions as well as various combinations. It did not reduce the gain by more than about a 1/3 of a db in any combination. I tested the output recording test tones and music (12ax7 to 5751). It really didn’t change the volume output in any usable way even with all three positions holding 5751 tubes. It did make it a bit more bright sounding with less bass so I guess there is that.
