Arkay
Lunatic Member
Something has been rolling around my head for a while...
I use a record brush when cleaning LPs with my VPI RCM... but like many people, sometimes I will give a dry record a brush, too, to remove any surface lint/dust just before playing. I try not to ever touch the brush with fingers, or let it touch anything but the record surface, but...
If a record brush helps remove dust from a record, where does the dust go? Obviously, some of it falls off the edge of the record, some flies off into the air... and SOME is bound to stick to the record brush, even if it isn't particularly adhesive nor carrying a static charge.
Over time, there is bound to be some dust ON the record brush. That dust might even potentially cause micro-scratches on the next record that is "cleaned" with the brush, mightn't it?
I recently got a turntable that came with the previous owner's record brush. I found myself wondering... is it clean? Do I dare let this brush with an unknown history touch my precious vinyl? How do I know/make sure that the brush is clean, and won't transfer some gunk or dust to the record surface? Yet it seems a waste to throw out a brush that at least looks fine, though, since it may be perfectly fine and usable.
I haven't hauled out a microscope to inspect the brush, the way I inspect styli... which might show if it is clean or dirty. Has anyone here done so?
I guess the key question is: HOW DO YOU CLEAN A RECORD BRUSH (or keep it clean)? Run it under water? [I've tried it...don't know if it helped.] If so, tap water or distilled? Use detergent or record-cleaning fluid, followed by distilled water, as one might with a record?
What do you do to keep your record brush clean? Is there an accepted/expert method for this? I don't recall reading of any. Any wisdom shared will be appreciated.
