metaphile
Hello audiokarma,
First post here. I'm in the process of restoring a Sansui QRX-7001 that I inherited from my late father earlier this year. I didn't even know how to solder when I began in June - by now I've completed two DIY amplifiers and a preamp and have recapped and replaced (some of) the transistors in all the boards in the Sansui's 2-channel audio path. I am obsessed with this hobby and deeply grateful to the folks on this forum and at diyaudio for all the knowledge y'all have shared.
I was lucky to find that the receiver was in working condition when I began. It sounds significantly better w/ the new caps and transistors. That said, I still have enough hiss from the speakers (90dB sensitivity Infinity 3000 3-ways) that it's audible from the listening position. In addition, the balance, bass, treble, and volume knobs all seem to impart some hiss and crackle.
I already removed and re-capped the tone control board and replaced some of the purported-to-be-noisy transitors. But I didn't clean the pots. I now have acquired some needle-tips and a few types of contact cleaner (QRC contact cleaner, Deoxit Fader F5, Deoxit 5%) and I'm looking for some advice:
On another topic, I have only recapped the two channel audio path and power boards so far (no room in my Brooklyn apartment for rear speakers for quad!) but I did cycle through the switches for the various quad decoding modes last night - one of them (Synthesizer Surround) caused a very loud pop that seemed to engage the speaker protection relay when enabled. Others hissed even louder than the 2-ch direct mode. This gives me additional motivation to go ahead and finish the job and recap / replace transistors on all the other boards, even if I am only using two speakers at present.
Also, I was lucky to find that there were no fusible resistors on any of the boards I've done so far! Additionally, the pots on the driver boards work perfectly, so I haven't had to replace those. Amp biased perfectly and DC offset is near zero. It was kept in a cool basement for many years and was rarely listened to since my mother banished it from the livingroom, so it's well preserved. Serial #23408011 for the curious.
- What is the best way to clean inside the sealed pots and switches in the photo? I have read some recommend drilling a small hole w/ a tiny hand drill and using a needle tip to spray Deoxit inside and then actuating the pot many times (from xraytonyb's Youtube channel - forgot which video). Seems I'd need to drill holes to access each layer of discs inside, yes?
Others have suggested de-soldering and disassembling the pots.I have never disassembled/reassembled one of these and am a bit intimidated by it, as I don't have any spares. Looks like I'd have to bend and re-bend the metal tabs that hold the discs inside?
Any advice on how best to approach this would be appreciated.
- Which type of Deoxit is recommended for these types of pots? I assume regular Deoxit 5% is best while the Fader F5 is preferred for the plastic push button switches. Correct?
The hiss you are hearing is background noise being amplified. If it is there with volume at zero, it's in the power amplifier. If it is quiet with the volume down, and increases as you turn it up, it's in the pre-amplifier stage(s). If it is worse on Phono, then..... Yep, Phono stage(s).
