I baught an used PBN Groovemaster TT running on a Clearaudio motor and VPI HR-X platter. It is driven by a Pro-ject Speedbox SE. The seller told me I need to set the reading on the Pro-ject Speedbox to 35 for 33.3rpm, and 47.1 for 45rpm lps. I asked him why, he said it is due to the diameter of the VPI HR-X platter is different (bigger?) to the Pro-ject tt platters. I listen to my lps at both speed, and believe it is correct setting. Does anyone here have the same experience with speedbox and platter/motor from different manufactures? Is this normal? In my case, if I upgrade the speedbox to VPI SDS or Clearaudio Syncro in future, should I use their normal settings at 33.3/45 rpms? Thanks for your advices.
David [/b]
David [/b]
