MunchsUncle
TV Fans:
CCEXTRACTOR works to watch programs with captioning data in the program on a PC. It requires a .net 3.5 framework and the only Operating Sytem I have successfully tested it on was an XP Home PC that I built. The PC that it is on is a 32 bit AMD PC Chips Motherboard with an Athlon Processeor and 1 Gigabyte of RAM. The video card is a 256 Megabyte ATI which is run through a Belkin KVM switch to an Acer 19 inch LCD monitor. The ISP is a Wifi company that put an antenna at the top point of the house.
Just go to www.brothersoft.com and search Windows for CCEXTRACTOR.
There are other Operating Systems supported by CCEXTRACTOR, such as Apple Co. Operating Sytems and even Linux supported, but the only one I know that works is the XP Home with the .net framework installed. The program for Windows will automatically ask for the proper .net framework when installed and before finishing. The program will install the .net framework automatically.
Some Proprietary DVD software will caption and Hulu is at least partially captioned and CCEXTRACTOR is not needed in those cases. Just read the instructions on the CCEXTRACTOR Website.
The uses for this are obvious, you can watch TV at work and no one will ever know.
Munch's Uncle
Munch's Uncle
