CM Labs CC-50s Rebuild
Salbreth1
Hey guys, I'm looking for a service manual for this integrated amp but cant seem to find much info on it. When I got it it worked, but someone cut a resistor out and left the leads hanging on the relay board. The board is pretty burned up too. I already started rebuilding it, but would like to know what was there. You can see the through holes right below the big 6 ohm resistors. Thanks
Sal
I'll guess the parallel pair of resistors were replaced by that one resistor. Do the solder joints look newer?
I thought the same but the joints look original and the resistor that was there is original unless replaced in the 60's. Whatever happened took out the diode as well. I've been searching forums for a good shot of the board but no luck.
