well if Google says it then it must be true. Guessing you mean an 'AI' search. You realise that only draws its answer from what people have written on the internet, much of which will be incorrect?Google says early CD players had errors in the 10-100 nanoseconds range, which makes more sense, because that's one of the reasons they continued to develop the technology.
Happily we have jitter tests of some early players. In any case, timing errors in nanoseconds would still only be audible with test tones, not music, so even in those cases it's still not an issue. Tape and vinyl do have audible jitter levels, people still use them quite happily.
True but there is an analogue equivalent. Audible jitter sounds like tape wow. That's not a coincidence.Jitter is exclusive digital termThere is no analog jitter. You can not hear digital jitter of course but it affect DAC and sound after DAC.
IMO/E, "Flutter" would be closer to the tape equivalent of digital jitter.True but there is an analogue equivalent. Audible jitter sounds like tape wow. That's not a coincidence.
Agree.IMO/E, "Flutter" would be closer to the tape equivalent of digital jitter.
Agree there is not the same cause but I'm suggesting the effect in analogue domain is the same. Although Bill is correct the distortion effect is more similar to flutter than wow. This isn't an issue anyway in any competent digital player.It is not and can not be trueJitter is not related to wow
Jitter explained - Part 1.3 [English]
Jitter explained, Part 1 on TNT-Audio - Internet HiFi magazinewww.tnt-audio.com
A fine bit of revisionist history, I thinkUnless some new evidence comes to light I'll maintain my position that it has never been an issue worth any concern.![]()
I know, still not sure I like this new feature of Google search tbh, my point was that if there wasn't an issue with jitter in early equipment, they wouldn't have needed to develop the technology, for example, my mid 90's Deltec DAC/transport uses an exclusive optical link to connect the two clocks.well if Google says it then it must be true. Guessing you mean an 'AI' search. You realise that only draws its answer from what people have written on the internet, much of which will be incorrect?
It probably just syncs the clocks of the two units, there's not a lot of information about these older DACs.
Of course two clocks can be synchronized. How do you think clocks all over the world are coordinated? The only question is the degree to which they are identical.
Hardwiring a clock signal between two devices generally gives better sync than recovering timing from a data stream. But even in a single device with a "single clock" there is not perfect agreement of the clock signal at all points in the circuit.
No, I'm not.You are talking about clocks at train station.
You wrote: "Of course two clocks can be synchronized."No, I'm not.
Did you read my whole post? I don't see any point to your links.
I think you must be just here to argue.
