baneste
I have a Magnum Dynalab ST-2 whip-style antenna mounted in my attic. I am currently using it for FM reception only. The manufacturer says the antenna is also good for AM reception as well. The antenna uses coax cable connections. The manual for it makes no mention of how to properly use this antenna for AM reception. Two questions:
1. May I use this antenna for BOTH AM and FM reception or would I need two separate antennae with one dedicated to each band?
2. If I can use one antenna for both AM and FM, what is the proper way to connect it to the AM and FM connectors on my tuner? Should I split the RG 59 cable and run one split to the FM terminal and the other through a balun to connect to the AM terminal?
BTW, I realize a longwire or loop antenna is better for AM, but it would really be handy to be able to use this (or at least the same) antenna for both because of difficulty in getting a second lead from my tuner's location to the attic of my home. Thanks in advance for any assistance.
