When Shure came out with the beryllium cantilever, they used the stiffness-to-mass ratios to compare it to that of aluminum and explained how the beryllium had the lowest effective mass which resulted in superior high frequency tracking ability and a high frequency resonance beyond 20k Hz. It also lowered distortion and increased transient response. That comparison seemed valid since Shure compared a beryllium tube with an aluminum tube. I now see other manufacturers coming out with exotic cantilever materials hoping to ride on the coat-tails of the Shure beryllium cantilever but there is one big difference: All of these cantilevers (boron, sapphire, ruby) are solid rods. I’m not sure if the advantages claimed by Shure makes sense when you compare a solid rod to a tapered thin-walled aluminum tube. Is the mass of a solid beryllium rod lower than an aluminum tube? I tried a crude comparison using a Precept PC440 (beryllium rod) to a Precept PC220 (tapered aluminum tube).
I weighed the two stylus grips making the assumption that the only difference between the two was the cantilever (I could be wrong, but the two physically look the same).
The PC440 weighed 1.170 grams and the PC220 weighed 1.165 grams. The grip with the aluminum cantilever either weighed the same or was slightly less than the beryllium. So, it appears that the use of a solid rod cancels out any low-mass advantage one may gain over an aluminum tube. I’m not sure if my logical holds any water but I’m really hesitant to spend a premium price for one of those exotic rods to find out.
Beryllium Rod:
Aluminum Tube:
Beryllium Rod:
Aluminum Tube:
