Howdy all, I finally was able to pry loose from a friend an X 202B that I have been looking forward to. A PS rebuild was first conducted with replacement of resistors with low-noise carbon films that were also uprated wattage-wise. I did a comparison with a rebuilt X 202 that I had been using in rotation with a Scott 299B, which in the bass dept. has been really disappointing, not sure what is going on there except that I believe the phono stage must have some built-in roll-off in the bass, just no comparison to the X 202! In comparing the 202 with the 202B, the B just sounds piercing and roll-off in the high frequencies while in the bass it is much better than the Scott but does not have the quantity or quality that the 202 has. Also, the phono stage is hissier than the 202 by a fair amount. The current rebuild did not include rebuilding the bias/DC source yet, nor replacement of the cathode bypass caps or the 1 ufd cathode follower caps. Does anyone have any ideas what may be going on here, do I just need to finish the recapping before getting a clearer picture of the capabilities of the X 202B. Perhaps I should be looking to go with DG's X 202B rebuild article? thanks!
