Comparison of Neo vs SmCo EMIM Strength
Maxamillion
So I picked up a bunch of assorted EMIM/EMIT parts from the auction place - two neo EMIMs and four SmCo EMIMs w/o diaphragms, along with two EMITs with bad diaphragms. I was able to get one good neo EMIM out of the two (minus corroded/detached magnets), so my RSIIbs now have a complete neo set (yeah!). All the SmCo EMIMs are fine, as they don't corrode.
Just out of curiosity I did an experiment to see the relative strength of the neo vs SmCo magnets. On my EMIM jig, I suspended the front plate over the back plate for each of the EMIMs and measured the gaps with the top plate level. The neos all had a gap between the plates of 3/4", while the SmCos all had a gap of 9/16"; it was a noticable difference, and remarkably consistent. The force required to push the plates together was also noticably higher with the neos. I would guess the stronger field would translate into higher efficiency and a bit lower range for the neos.
Just thought you might want to know...
I have a related question.
I have RSIIIa's which came with SmCo Emits. At some point in the past (not knowing the magnets were different) I replaced the ribbons and back magnet assembly with Emit K parts. At the time infinity showed the ribbon itself as the same - it didn't occur to me that there would be different magnet strengths.
So I now have one set of tweeters with Neo backplates and SmCo fronts and one set with SmCo backs and Neo fronts. I never noticed any sound difference and wanted to keep the front plates on their matching speakers. If there was a sound difference I would have attributed it to nice tight new ribbons, not magnetic differences.
Does anyone know if mismatched front and back magnets will affect SQ? I could not tell a difference side by side, but when I listened to them side by side they were running without the rest of the speaker, so differences may not have been as noticeable.
I still have both sets, so if I need to swap them back I can, but I hate to disturb working speakers.
If they sound good to you, then leave them alone. I know that would drive me crazy, though, probably to the point of taking them all apart and trying each of the different combinations:naughty:. It may not make much difference in sound - the higher field strength may just make then a little more efficient. I believe though that in the EMIMs, the higher field of the neos extends their lower cutoff point a bit, allowing them to mesh with the woofers a little better.
