dogwan
Dogwan
Picked up a NOS quad of those infamous 6AV5GA's that are labelled 6B4G.
Apparently the story goes that in the mid-70's Sylvania Philips had a military order to fill and they realized they could Triode strap the 6AV5's and give them the same pin out as the 6B4G and they would perform the same.
Anyway, I have a DIY PP 6B4G amp that I picked up a while ago. Have been using some '79 date codes Svetlana Winged C 6S4S tubes and it sounds great. But it is a little light on the bass. Wanted to try some different output tubes so picked up the aforementioned JAN (pseudo) 6B4G's.
Here's my original thread on the amp.
When I installed them I get horrendous AC hum out of the amp. It's more than just an adjustment. It really is quite loud and overrides any music that might come out of the amp. With the Russian tubes, or the mis-matched real 6B4G's that came with the amp, it is nearly dead quiet.
I am guessing it's something to do with the the 6AV5's being IDHT vs. the 6B4G and 6S4S being true DHT? I don't really know enough about that. But, I would have thought that if the tubes were sold for military applications as a plug and play drop in for 6B4G that they should work in my amp?
Any thoughts?
I've attached the data sheets for both the 6B4G and the 6AV5.
Here's my hand drawn schematic of the amp (based on Eico ST70 iron).
The tubes in question...
The amp...
Recognize this diy 6B4G PP amp?
Did some horse trading recently and picked up this DIY push-pull 6B4G amp that looked interesting. Definitely needed some re-work but it has nice parts. Someone wrote in the inside "Built 1997, JB" or something close to that, in red sharpie. I don't want to comment too sharply on the...
audiokarma.org
Any thoughts?
The amp...
