Connect my Rotel Amp - Equaliser- turn table -CD player
Put the EQ line in and out into the Tape 1 in and out. Turntable into phono, CD into aux.
That Rotel should work great.
Thanks a lot. Just to clarify, did you mean
EQ line OUT to Tape Monitor 1 IN (of the Amp) and
EQ line IN to Tape Monitor 1 OUT (of the Amp)
CD player and Turntable direct to amplifier
And I don’t need to play around with pre-amp and main amp pin -correct
them ins and outs always confuse me . does no harm if connected backwards .it just wont work properly . think you also need tape monitor to on,
pre main jumpers stay in place ..
Yes, the Pins or Jumpers are if you want to use your Rotel Integrated Amplifier as a PreAmp,in which case you would remove the Jumpers and connect a Power Amplifier,(which is mono & the Pre converts it to a stereo signal), if you felt the need for more power from your system. Otherwise follow MRV8Q's advice. Enjoy.
Yep!
Just to clarify for the OP, turn on Tape Monitor when you want the signal going through the EQ. Otherwise if you leave Tape Mon off, it does not go through the EQ. The source selector should always be set on whatever source you want to listen to (CD, etc.).
