Connecting Active Subwoofer (Dayton Audio CS) to Vintage Receiver (Marantz 2270)
Wilfred Jone
How can I connect an active subwoofer (Dayton Audio CS) to a vintage stereo receiver. I have a Marantz 2270 and it's currently connected to two Bose speakers. The audio source for the Marantz will either be a turntable (phono) or a computer (aux). Is it possible to connect the subwoofer through line level?
Yes you can use the hi level inputs. This can be taken from either the speaker binding post on the back of the amp or from the post on the back of the speaker. And you should use the post on the back of the amp that the speakers are actually wired to not a B set. You have to have the positive from both speakers and you can get away with just running one common and then jumping on the back of the sub.
Is there any way I can use line level input?
If you get 2 male and 1 female style you can plug the 2 males into the preout - main in and use the female for the cable going to the sub.
Gotcha. Horizontal Y-splitters, replacing the R and L jumpers connecting MAIN-IN to PRE-OUT, with the female ends of the Y-splitters each connecting to a longer male-to-male RCA cable, with the other male end of each connecting to the subwoofer's R and L line inputs, respectively. Thank you very much!
What about using pre-out and main-in?
I assume the sub is going close to one of your Bose speakers. Just daisy chain off of one of them to one of the speaker inputs on the back of the sub (output adjusts just like the speaker it's attached to). Been running same subs for a long time with no issues. Especially not an issue when playing vinyl since the bass output of a record is centered.
Welcome to AK!!
Thanks you for posting pictures. Most new members (and some oldies) ask questions and never post pictures of the equipment in question, expecting us to do the legwork in searching for the pictures. It definitely helps in getting a quicker diagnosis of the problem.
