Hello,
I’ve recently gotten my hands on a dual 1224, I restored it and it seemed to be working almost perfectly. To test it, I had connected it to my vintage HiFi system via the turntable input socket (Wega System 3220, with similarly a dual turntable and and a WEGA receiver with EQ). Up until testing it with my WEGA system, everything seemed perfect.
This is a turntable I intened as a gift, so I cannot use it with my own WEGA Hifi system though. I had thought switching the pre-amp would not cause any trouble though, until I actually tried it with a new preamp to be intended as part of the gift. Unfortunately, unlike with the WEGA system, connecting the dual 1224 via a DIN 5 pole male - stereo RCA male adapter consistently caused the right channel to go away / just produce huge humming. I don’t understand this, as the DIN-RCA adapter is not faulty (I’ve used it successfully with other turntables), I merely switched the preamp. Actually, I tried 3 different preamps (Behringer PP400, Behringer PP500, and N-Audio AK750S), and they consistently produced the same problem. I’ve alslo tried replacing the carttridge on the dual 1224 with the cartridge from my dual 1229, which definitely works, but that AGAIN shows the same problem. The same cartridge works fine on my WEGA system though.
I don’t understand why the Dual 1224 only works with the preamp on the WEGA system but no other pre-amp. Am I missing something / does the vintage WEGA preamp have some extra hardware not present in the modern pre-amps ?
