GearHead454
Still Lost
Long title sorry about that.
I have a Modwright preamp (LS100) that has XLR inputs that are specifically noted as being "wired single ended". I am about to get a Lumin D2 DAC/streamer that has XLR outputs noted as being "balanced".
I did a little reading to understand the difference in how the signal is carried in XLR when wired single ended and when wired balanced but I haven't found whether it's safe to connect equipment with XLR when one piece of gear is single ended and the other piece of gear is balanced. Also whether there is any actual reason to use XLR over RCA IC when the XLR is wired single ended.
Anyone with expertise to share on this would be much appreciated,
Thanks
Thanks
