Steve at JM Technical Arts refurbished my Revox A77.
Now its time to use it and i have read and confused myself to paranoia.
I want to start recording. First, i have a DVD player that plays SACD. I want to connect it up.
Do i need to go through a preamp first, like the one i use for my record player to boost the signal?
Do i than connect it to the Aux input on the Revox rather than the Mic?
Would these 2 questions apply to a tape deck as well?
I would like to monitor over my tube amp system as i record. I understand the Revox has an internal amp.
Does the Chan1 and 2 Output rather than Speaker bypass the internal amp?
Thank you!!
Will
So i have been playing around. Player is ran to the Aux Input. Output to the back of my Amp. Monitor dials set on Stereo and other set to Input (not IEC or NAB). Record dials on Aux and Aux. Meters working, adjusted the levels to just about touching the red. I can hear music.
Going to assume i can record? New tape i have is tails out so i know to rewind it to another reel.
Another question.....Balance. Turn it all the way to the right the right speaker much louder. I can still hear some music from the Left. Same with the Right. Turn knob all the way to the right, some music still from the Left.
This seem correct?
Thank you!!
Will
This seem correct?
