Connoisseur BD 103 power supply info needed
ghbrian
Hello
I picked up a Connoisseur BD 103 Turn Table, but it is lacking the external power supply. I cannot find any information on what the correct output and AC or DC is. Perhaps somebody who knows the answer and reads this will respond.
Regards and best wishes
just done some digging around and found the owners manual . the power supply diagram is in there plus the circuit diagram for inside the unit .
the power supply looks to be AC for the strobe .and DC for the circuit . no voltages marked but i can hazard a guess 12v DC should get it running apart from the strobe of course .
i got the 12v from there being a 8v zener diode in the regulator . and lots of things run off 12v .
supply needs a 500ma fuse so a 1 amp supply should run cool .
manual here . free sign up .. http://www.vinylengine.com/library/connoisseur/bd103.shtml
OK, I went to Goodwill and picked up a 12 volt wallwort (power supply) and figured out the line in for the motor, and got it spinning. Now I have to pick up new drive belt. Thanks, I too, thought it might be 12 volt.
The cart on the tone arm is a Denon DL 103S, and appears to be good.
