I won't unwrap the posts, but what's so peculiar about them? They were originally hand-wrapped, no?
Turns out there's several types of capacitors.
Is there a specific type to look for, or just not electrolytic?
There are plenty of electrolytic caps in the 650 that can be replaced (if original) for a positive effect - with LOTS of signal coupling caps. I get REALLY tired of advice that's coming from those that know nothing
about the unit, and don't take the TIME to FIND OUT FIRST........ I don't mind correct advice - it saves ME typing - but I have to type MORE when it's necessary to correct things.
The caps could be tested individually with an ESR meter to find the ones that have either gone bad, or gotten marginal. Then repeat every year or two until all are replaced.... or do it all at once for another 20 - 30 years.
Electrolytics are small plastic covered metal cans with rubber seals where one or both of the leads come out. They use a water based chemistry that stops working when they dry out. The hotter the area they are in and the cheaper the seal, the sooner they die.
There's another type called tantalum electrolytics, and for OTHER reasons they too should be replaced (with an electrolytic too). THAT'S why I recommended using the capacitance VALUE as a guide (found in the schematic and manual's parts list) as to what should be replaced.
So yes, re-capping (the electrolytics) extends the life, as long as you don't put them in backwards and blow something up.
The wire wrap's square post cuts into the metal of the wire and forms a "gas-tight" connection, which at that point doesn't corrode. The CUT weakens the wire which can break off short on disassembly, or SURELY on re-wrapping IF you have the CORRECT tool (not easily found anymore!!) applying the correct tension, and that broken off short wire will be a REAL problem.
