Considering upgrading coupling caps on C32
chaslieb
Got a well loved c32 that was restored in the aughts with soldered ribbon cables to replace the delaminated press fits and new caps. Unfortunately the phono and input caps are mostly polar electrolytics. The inputs on the phono stage are 3.3uf and everything else is 2.2. Has anyone found tiny film caps that can fit in the small spaces these lytics will leave if replaced?
film caps will likely be a bit too large to fit. Your other option is to add .22 and .33uf film caps as bypass caps to the existing or new electrolytics. Have done that several times on various models.
