Mister Pig
Pigamus Maximus
Earlier this year I came across a test record put out by Realistic, Catalog 50-1001. There is a track for channel balance that has equal levels of white noise in each channel. I was wondering if it would be possible to play the track and measure the output of each channel at the RCA jacks with a multi meter. It would seem that if azimuth were correctly set, then each channel should measure the same output. Yes I understand that the cartridge will have some variation in each channel, but they still should measure very close I would think. I would also think that my ZYX should have closely matched channel levels, certainly given its price point it should.
Is there any reason why this method wouldn't work? Are there any points to consider about the best way to perform the test? The tonearm I own is a uni pivot design, and uses a pin and snubber assembly to make initial azimuth adjustments. So the arm can be adjusted quickly and easily. A set of side weights are then used to bring the pin off the channel, and allow the arm to properly float free of the assembly. I am curious to see how close my azimuth setting is now, for I feel I have it correct.
Thoughts/opinions?
Regards
Mister Pig
Thoughts/opinions?
Regards
Mister Pig
