Hi all,
I just bought an old but brand new Tivoli 'Model One' radio (platinum series - yay!). I suspect this thing is near 20 years old. Stations come in and play clearly, but... while I'm still dialing in a station, the audio output can be quite scratchy/noisy. The volume knob works flawlessly, though.
So, the most common solution, I've read, is take out the back screws and pop-out the front panel and give the station-dial a cleanse. And while I'm doing that, I may as well do the same for the volume and input selector knobs.
I'm not an electronics type of guy, but I think the volume (and input selector?) are known as pentiometers... but not the station-dial, which I think is called a 'varicon'. Someone - please correct me if need be. The varicon seems to be all metal sheets... though, has a dialectic element to it, from what I can tell. There's a Youtube video showing the Tivoli varicon, here:
In any case, at home, I have some DeoxIT D100 and DeoxIT Gold contact cleaner spray.
Question: Is the D100 okay to use to clean and lube the varicon, or do I need to buy and use some D5, or completely change over to the DeoxIT Fader line and get the F5 or F100 solution (better for metal on plastic)? And would the same spray be fine to use on the volume & input selector knobs?
Thanks!
Thanks!
