I'm reworking a PL 400 that was converted to balanced XLR inputs sometime in the past. I'll be installing the Watts Abundant protection relay board from AKer Dimlay3 and converting back to unbalanced RCA inputs using the new jacks supplied in the kit.
The installation instructions show that the RCA input jacks are mounted on a copper strip inside the chassis that has ground wires soldered to it. I think there were also insulating fiber washers there originally to insulate the RCA jack grounds from the chassis. The original copper strip and fiber washers are not in mine so I want to put it back in stock form. It looks like they set it up that way to create a single point ground to reduce ground loops and hum.
Could a PL 400 owner check to see if the copper strip is electrically isolated from the chassis? There may be some sort of insulating tape or other material between the copper and the chassis or maybe it's in direct contact.
This picture is from the Watts Abundant relay installation instructions.
Thanks. --Dan
Thanks. --Dan
