Carl G
avguytx said:Just buy my Valencia 846B's and be done with it. They need a good home! lol
The above might be the best suggestion thus far. I've owned Cornwalls, Fortes and A7s and various modded versions of Valencia 846As, Belles, and Klipschorns. Certainly, the jump from Fortes to Cornwalls or big Altecs will give you a larger sound, but I've always preferred the sound of certain Altecs to that of Cornwalls. The mid horn for the Cornwall is undersized and shrill when pushed to any decent volume, and can be unpleasant even with tubes. Hence, some Klipsch modders have kept the Cornwall bass cabinet and replaced the upper end with similar horns that are in the K-horn or LaScala (nicknamed the Cornscala). Strangely enough, I have found the mid horn of the Forte I to be smoother than the Cornwall's mid horn (even given the relative sizes). That being said, I found the Cornwall II's mid horn to be an improvement over the original so if you are going the Cornwall route, you may want to look for a pair of Cornwall IIs.
As for bass, the Cornwalls do load the room with bass - especially for rock 'n roll. Valencia 846Bs are also great rock 'n roll speakers, but have a much smoother horn (811s). Some of the older Altec drivers did not extend up high enough for my taste, and if that is your experience, you could always add a tweeter up top (which is what I did) or change drivers (902, 906) to gain upper end frequency extension. I also prefer the Valencia's bass as being slightly tighter sounding than the Cornwalls, but there are many fans of the Cornwall bass response.
I'd say that the quest is worth it, but given the two choices, I'd go Altec. Of course, I'll always encourage the quest as I have little room to talk.
) green painted tube amp that apparently is auto/self biasing with a whole host of output tubes. I've e-mailed the seller/builder for some more info, and actually forget to ask him for the specs, but will when I hear from him....Cableguy may be able to provide more specifics....
