counterfeit output transistors
By running the amp up to clipping with an 8 ohm and a 4 ohm load, and leaving it there for a few minutes (a power bandwidth test isn't a bad idea as well). If it can handle that, I'm pretty convinced that the parts are good.
Hi everybody, specially EW and best newyear 2013 wishes from France !...
I think EW remembers me at the time i had to repair the output stage of my Sansui AU-9500 last april...
He suggested to me to use On-Semi transistors from a reliable seller : i did it and no regret at all, my amp is still sounding great u to now.
So don't hesitate to follow EW's advices...! He knows about this stuff !
Rgds...
Hi All,
Are replacements output transistor for the 9090db no longer available? All the information I see in this forum leads me to believe this. Thank you.
The original outputs were discontinued many years ago, but On-Semi makes a number of good replacements, such as the MJ21193G and MJ21194G. These should be purchased only from an authorized reseller such as Mouser or Digikey or Newark.
Hi,
Thank you so much for this info.
