I just acquired a counterpoint sa-2 but the fuse was missing. I can't find what fuse is required in any of the online info (schematics or owners manual).
Anyone know or have a unit that you could check for me? huge thanks!
thanks kcin...any help would be appreciated! I was told a 2A is the appropriate rated fuse...but the unit popped it. So I'm not sure if there is an issue or if the 2A is too small.
2A or 3A is a fairly common fuse type for most standard tube type amplifiers like RCA, Magnavox, Voice of music, and Motorola type amps. Anything else like higher power amps will most likely use 4A and above.
The SA-2 owners manual says the unit consumes 75W at 120V. It does not list the size of the fuse needed, but from the wattage consumption, a 1A fuse should do it, and a 2A fuse would give plenty of headroom. Agreed there is something wrong with the unit if its blowing a 2A fuse.
