ddanrr
Member
I have a couple of Infinity questions, so I thought I would present them to the experts here. I have the RS-4B and want to use some Howard Restore a Finish on them to spruce them up. I would like to hear from anyone who has already done this, what Howards color would be best for the Infinity finish? I have a pretty full can of walnut already. Howards also comes in Golden Oak, which seams like it would be way too light, and Dark Oak, which doesn't look much different than the Walnut I already have. I think this RS-4B oak finish is the same as the RSIIIB, RSII, etc. So what color have you guys used?
The other question regards woofer refoaming. I have already refoamed the 4B's woofers but turns out one of them ended up having a bit of voice coil rubbing, only heard during loud bass heavy passages. I have pulled the woofer and undid the surround where it meets the cone to try to fix it. Using the method where it naturally centers won't work on this particular woofer, it centers in a crooked position, which is why the first refoam didn't work out. Test tone doesn't do it either. My first thought it to shim it to get it right, but I've heard the 902-5030 4B woofer is sealed in the center (under the dustcap) with a little plastic bullet like on the RSII woofer. My question is, is there any way to still shim the coil, will this plastic come off at all? I have shone a flashlight through the dust cover, and it kind of looks like it might come off, but dont want to wreck the dust cover if this is not going to work.
-Dan
-Dan
