nyhifihead
Well-Known Member
Hey all I've noticed the hafler p7000 class a/b MOSFET I've had on duty powering the 2 12" low end in my NHT 3.3s has been running very hot.
The thermal protection light hasn't gone on even under heavy load but I know it can run cooler. Its 8x MOSFET transistors per channel that run in an atypical actively cooled setup.
Air is pushed back to front from the rear fans and the hot air blows out the front. The mosfets share a pseudo aluminum heatsink next to some case vents.
Under the aluminum strip there's some white caked up thermal paste due for a refresh, I'm wondering if CPU liquid silver paste would work on these between the MOSFET and aluminium
Here's a pic for reference.
I also ordered some Korean 60mm silent fans to replace the stock ones that are pretty noisey
