Nuklhed
Greetings team! Got a clean 1040 on the bench, trying to save her. Here’s the scoop so far.
1. Protection will click, but have to turn the volume up to about 7 to barely hear both channels.
2. Readings into and out of the power supply look very good.
3. From my experience with 840 and 1040, the output packs seem to be good.
4. I took the pre driver readings below with the unit energized, speaker off, output packs installed.
Pin Right channel IC 602. Left channel IC 601 Schematic says
15. 50.2. 50. 50
14. 1.4. 3.2. 3.0
13. -4.4. -3.2. -2.9
12. -3.8. -2.8. -2.8
11. -1.2. 0. 0
10. -1.3. 0. 0
9. 0. 0. 0
8. -1.2. 0. 0
7. 1.2. 2.7. 2.7
6. -49.7. -49.7. -50.5
4. -48.2. -48.2. -49
3. 0.2. 0.3. 0.1
2. 0. 0. 0
1. 0.2. 0.3. 0.1
Looks to me like the left channel nearly perfect. I do have a backup predriver, but before I just shotgun it I’d like your take. Be glad to take any other readings you feel may help. Thanks in advance for any thoughts!
15. 50.2. 50. 50
14. 1.4. 3.2. 3.0
11. -1.2. 0. 0
10. -1.3. 0. 0
9. 0. 0. 0
8. -1.2. 0. 0
7. 1.2. 2.7. 2.7
3. 0.2. 0.3. 0.1
2. 0. 0. 0
1. 0.2. 0.3. 0.1
