mjdupuis
Be not rash
In this case I may have just enough information and knowledge to be dangerous.
Before performing Service Bulletin Mods the left channel performed at a slightly weaker level than the right based on observation of the sp meters, though there was no audibly discernible difference.
After performing the Service Bulletin Mods I set the bias with readings at Left- 10.5mV and Right- 10.0mV and checked DC offset with readings at L- 1.1mV and R- 21.1mV.
While the amp was apart and accessible I decided to do some research on correcting DC Offset on the CR-2020. (I must note: I am not doing this out of necessity; I don't believe this is a serious issue but a slight one I believe can be easily fixed. I just noted that something was a little off and wanted to optimize everything while it was on the bench.) From what I have gathered replacing the differential pairs on the corresponding Main board (Left in this case) is the best way to correct the DC offset. If I am going to replace the differential pair should I replace the pair on the Left and Right Main boards together? The Zetex ZTX795A was mentioned as a possible replacement but is this the best match for this application? Does anyone have any experience with a more exact replacement? Since this application calls for closely matched transistor pairs, does anyone have any advice on pairing them up? Thanks in advance
