hertzdonut
Press Play and Stand Back
Brief background on this CR-2020: With the help of this forum, I got this beautiful unit up and running about 5 years ago. All good. The last couple of years, due to moving and life in general, it got very little use.
Recently, I started using it again as part of bedroom setup. I noticed switching through various Modes (Stereo, L, R, etc) would result in improper playback, meaning, I would get playback L & R even if Mode was set to L, switching Mode to Stereo makes the R signal go weak, etc.
I suspected a dirty Mode switch as well as Volume and Balance knobs and decided to finally take a plunge and open it up. Once the case was off, I pulled that upper Tuner Circuit Board and moved it a bit so that I could get better access to Deox'ing the switches and knobs. Over a period of 5 days, I sprayed DeOxit multiple times into the weep holes, and worked the switches and knobs hundreds of times.
Decided to fire it back up, no change. Well...heck.
Time for more work...(First a note about work I completed from 5 years ago: All Service Bulletin work completed, new outputs on the right channel, replaced a couple caps on the Power Supply Boards and the Electrolytic Cap Circuit Board. Replaced the Cap Coupler thingy. After that, like I said, all good.)
FF to this week: In addition to DeOx'ing the switches and knobs, I also removed the Cap Coupler from the back of the unit so that I could DeOxit that. Worked that switch a hundred times. With those massive heatsinks pulled, I removed the Main Circuit boards and replaced the 458 transistors on each board. Triple-checked my outputs (removed from circuit) using the six-way diode test. All good. Lastly, gave little tweaks to the Idle Current with the trimmers, left is reading 10.2, right reads 10.3. Near perfect.
Despite all the above, it hasn't made any change.
Which brings me back to my Post title...I don't know what readings I should get nor even where to take them, but decided to run through O, E, B+ and B- on the Main Circuit Boards and compare the L and R channels. My thought was each lug should be comparatively the same. I fire up the unit, grabbed my multimeter, and put ground to chassis.
Turns out, I got one reading different between the two. Here's all, from left to right, as if you are viewing the board from the component side:
Is that reading of -2.7 mV meaningless, or an indicator there's an issue somewhere?
Thanks,
Jeff
| CHANNEL | O | E | B+ | B- |
| LEFT | +7 mV | -.2 mV | +58.8 mV | -59 mV |
| RIGHT | -2.7 mV | -.2 mV | +58.9 mV | -59 mV |
Thanks,
Jeff
I dis-assemble so I can physically inspect components. The plastic pieces get the room temp water.
