I picked up a working CR-2040 that is filthy and running with High DC At the speaker terminals. So far I have cleaned the pots and switches and started cleaning everything else. Adjusted Idle current and DC Offset Baxter to where they need to be. I am looking over the boards for cold/bad solder joints and have noticed a rather large hot spot Where R-657, 648, 659 and 670 are soldered on the tone board. They are buried under the wiring and lacks good airflow. Has anyone addressed this issue and any other hot spot issues with the 2040? Seems to be a good candidate for relocation of the larger resistors for better cooling our upgrade them. There are a few other spots on the tuner board, see pictures.
