kcvintage
I have a nonworking CR-3020 amplifier board. I'm checking each board with +- rail voltage on (b) and no output transistors installed. Each of the driver transistor collector voltages (at TR609, 610, 616 and 617) reads approx. +- 10.0 V. Other transistor voltages read correct. Each driver transistor tests good on a Peak DCA75 tester. Why are all four driver collectors showing higher voltage than they should? Looking for suggestions to solve the problem. TIA!
