CR-420 with left channel distortion
Can't tell for sure..
The one in my cr 420 has writing on the cover, so I was curious if the one pictured may have been a replacement.
At any rate, I sprayed all the switches/controls that I could access and if anything I made it worse.....the distortion is now more pronounced with the tuner ( which was the one input in which the noise was previously barely audible). Unless there is something simple that I may be overlooking, perhaps it is best I take it to a tech.
Also, check for bad solder joints, particularly around the output stages. Plus - if it's anything like the CR-800, there will be 1.25" fuses underneath which can tarnish horribly. This will cause distortion, for sure.
I have similar issue with a cr 820 I just got. Distortion in right speaker. Very noticeable using aux and tape inputs, a little less with phono and hardly noticeable using tuner. Distortion goes away using headphones if both a and b speakers are turned off. The unit is very clean inside and I have cleaned the volume, balance, selector switches. I have also tried tapping the relay to no avail. Any suggestions?
I am still fiddling with this amp....cleaned contacts etc again and I checked the dc offset and it seemed fine, but when l went to measure idling current, and get readings of 0 on both left and right. How can this be or what am I doing wrong? Red to tp1 - black to tp2 - receiver on for 10 mins, speakers off, aux selected, vol at Minimum
both channels suggests a power supply issue ..its something in common to both channels ..get the supply checked first .
If your getting your +/- 29 vdc rail voltage. Then check that your emitter resistors R443-446 are still serviceable.
Well, I'm back and still having troubles. Life got in the way of playing with this for a few months.
Anyways, I haven't gotten a new relay yet, but I was poking around and I learned that the voltages on TR401 all tank when the distortion kicks in. They're supposed to be ~28V, but at low volume with the speakers on they'll drop to ~20V and will decrease more if I increase the volume. If I turn the volume way down or turn off the speakers they'll come back to ~28V.
I also checked TR403 and the collector follows TR401, the base is -0.14 which is about right, but the emitter measures -0.8V when the schematic indicates +0.6V. I don't know what all this means and maybe I still need a new relay, but I thought I'd check in before ordering.
As a side note, I bought a DS212 pocket oscilloscope and it's really fun to follow a signal through the amp!
Reading JPromo's thread about a very similar issue with his right channel, I tested my output transistors and one in the left channel does appear to have a short. Smacking that transistor also seems to bring it back for a few minutes (it's also near the relay). I'm going to go ahead and order some new transistors for the left channel and probably a new relay just for completeness. I'll post again after I get the parts installed.
Could even be a loose transistor pin socket or and cold soldered connection.
So there's some interesting results. After I pulled the transistors I tried testing them and didn't see the short. I went ahead and put in the new TIP41C/TIP42C for the left channel. It sounded great and the signal from my little oscilloscope looked great. For about 20-30 minutes. And then the TIP42C started smoking. Possibly bad R443/R445?
Where did you purchase your TIP41C / TIP42C?
Sounds like either non-genuine parts, or if they were from a reputable supplier, potentially a thermal / bias runaway issue.
You might have some new problems to fix if the output/s shorted.
i would first see if powering on with outputs removed can be done or if resistors needed in place of them to complete feedback circuit . then do some voltage testing to see whats going on .
I've pulled the transistor and it looks like there was some arcing between the retaining screwing and the back plate. The little screw insulator just fell apart too. The base to collector is definitely shorted. Can I turn on the receiver without the transistor or would that damage something?
