CR-620 Radio Problems
Bradley J
I just recalled my entire Yamaha CR-620 today and I got everything back together to find my FM sounds horrible, even when connected to an antenna. Also when I have the FM muting ON I still hear the static of the radio. Looks like I must’ve screwed something up. All the other inputs sound amazing except tuner. So not my channels sound horrible and FM muting doesn’t work. Any ideas? I made sure to triple check each cap and also made sure it was the right one before replacing.
Post some photos of all the parts you replaced in the tuner section. Did you try cleaning the air gap tuning capacitor? If so what did you use? Any oily film on the aluminum fins will detune you receiver.
I’ll get some pics of it tomorrow. There was oil and dust in the fins and cleaned it out with canned air. Also I’m not quite sure what the air gap tuning capacitor is. It might as well be that.
I replaced every capacitor with audio grade Nichicons besides the hidden one under the transformer.
Actually I believe it is called and air variable tuning capacitor.It is what the tuning knob/dial cord is turning.
Is there any specific capacitor that I need to use for the tuner section? I replace all of them with audio grade Nichicons. I also used an air can to clean those tuner fins. Maybe dislodging all the oil and dust caused something? I just have no clue where to start trouble shooting.
Do your tuning meters appear to work when you tune into a strong FM station? Do you get a FM stereo indication ? ( red LED) Does the AM tuner work ?
I get probably only 3 strong channels now and none of them go into FM stereo. Even though the channels are strong it still has poor sound quality. Also the FM muting doesn’t work. When the muting is on I hear no difference in sound and just hear the same static and faint channels. I’m not sure if AM works. I’ll have to check it out.
Look your solder work over real good for inadvertent solder bridges.
So I’m guessing the problem will likely be in the tuner section of the board and not anywhere else on the board.
C6CC54FC-0142-4BA6-B94B-6C227FB5BAD8.jpeg D7DB52DA-ACEB-4AA3-AFCE-7BD6B8161408.jpeg
That would be my first guess. Depends on if the AM is FU as well.
Just retouched some questionable joints going to these resistors and transistors and what do you know.... I have clear working FM again! One thing I did notice is that my pointer is detuned. The image below is of a strong channel that is 95.5 but on the pointer it reads 95.7. This is the same for every other channel where they read 0.3-0.4 channels higher than what they actually are. Looks like I probably did something to the tuning wire while I was in there. No biggie for me though. Just happy to have my recapped 620 up and working! Also just changed all the lamps as the old ones were burnt out. In person they have a more greenish tint that isn’t seen in the pics.
View attachment 1694746 View attachment 1694745
Thanks for all the help!View attachment 1694744
Swell...:thumbsup:
You can make that minor dial adjustment by simply sliding the pointer on the dial cord to a more accurate indication.:thumbsup:
