I have a CR-820 I am trying to get back into operation. Its had its driver transistors changed out with NTEs on the left channel and has a bad 2SC1624 NPN driver on the right channel. 3 of the 6 fusible resistors have been changed with the exception of a few 4.7Ω which I will replace later. It had a pair of shorted output transistors on the right side which I've replaced. All my testing is powered through DBT at this point, its not coming out of protection.
I'm trying to figure out the pinout for the NPN and PNP drivers. I am hoping a Yamaha guru out there will help me out. I don't see any pinout markings on the board. I can't make out any on the service manuals board diagram either.
I plan on replacing both pairs of drivers with MJE15032G/MJE15033G which are BCE.
I'm confused because I read a thread on a CR-820 rebuild that showed the MJE15032Gs with crossed legs for installation. I'm not sure why that would be unless the original NPN/PNPs are not BCE pinout.
