One or more may be kaput.The LEDS I used are pre made and I have used them on several Yammies,before.
My first thought when I saw the lights out was that the LED installed with a bit of a fight in the indicator went south. It was the first one I replaced.One or more may be kaput
May have a broken wire.My first thought when I saw the lights out was that the LED installed with a bit of a fight in the indicator went south. It was the first one I replaced.
Thats about what I figured.Measuring R501 I get about 41.5V on each side.
I will look at those connections,again. But they do look solid but will check again.A bad connection on/to L1,2,3 or 4 would put your LED's out of commission.
Diode check with ohm meter - forward and reversed bias ohms readingNot sure what a front back resistance check is but these are the readings with one probe on each point.
