Raphaz
Hello fellow Audiokarmians,
I get crackling, scratching noises, on both channels, on both receivers.
It's not constant, just every now and then. It can be dead quiet (when nothing is playing) for half an hour and suddenly, without me touching anything, it goes... "chrrk cr crkck chg chk" a couple times, then it's quiet again for 10 min. or an hour, then it comes again, and so on, no clear pattern. It's not super loud.
It also happens sometimes when music is playing – it sounds like a loose contact (scratching, popping, distortion, and short outings), usually only in one channel, not constantly either.
I checked all cables and speaker wires. That doesn't seem to be the issue.
Could it be some dials/knobs on one of the receivers needing Deoxit or WD40? But if so, wouldn't the crackling only appear when I actually turn some of the knobs?
Can it be the power outlet? I'm in a very old industrial building and electricity is a bit of a mystery. Sometimes the lights go dim for a sec when I turn on one of the receivers, or when the A/C comes on. If that's the issue, do I get some sort of power conditioner or something like that between outlet and receivers?
Any ideas on what's causing this?
Thanks!
Yamaha R-2000
2 x KEF Q500
1 x Klipsch R-112SW
Nikko NR-1219
6 x Minimus 7
MacBook Pro (mainly Spotify)
Technics SL-D3
Nakamichi LX-3
Some Denon CD player
Thanks!
Yamaha R-2000
2 x KEF Q500
1 x Klipsch R-112SW
Nikko NR-1219
6 x Minimus 7
Technics SL-D3
Nakamichi LX-3
