Yes (I presume that's AC audio voltages you're reporting). Looks like you're on the right track.
WIth four identical sections you should be able to measure voltages and compare. Piece 'o cake - right?
Me, I'd zero in on C27 or C58, both electrolytic coupling caps. Second suspect would be the input FET. However best to take this systematically - use your scope to probe the base and collector of each transistor (or the gate and drain of the FET) and see if/where you're losing the signal.... then compare DC quiescent voltages with the other channels.
