rocknroller
Got these pair of 4-way criterion for $25. Wood was in beautiful shape, great grill covers and cabinets nice and large so I think have some curb appeal for people. They have a "presence" about them. 1 woofer , 1 mid, 2 paper tweeters and 2 Metal dome tweeters. Unfortunately, while I expected a tweeter, maybe 2 worst case to be possibly dead, turns out all 4 of the paper tweeters are dead and 1 metal tweeter as well. Of course, no originals to be sourced (and certainly not in that quantity).
I was hoping for some cheap buy-out replacements from parts express, as I didn't want to sink a ton of additional money into them. However, the closest paper tweeter https://www.parts-express.com/t-25-2-1-2-paper-cone-tweeter-8-ohm--279-452 which is a bargain at $3.50 each (and probably better then the original tweeters) unfortunately has a 4" frame diameter. The original inset cutouts (for the frame portion) on the cab are 3.75", so I would have to lay them flat on the face. Any concerns about that from an air sealing perspective? Or know of another cheap substitute that might be a better physical fit?
Then there's the metal dome tweeter. I could replace the 1 dead one with a modern day soft or titanium dome but then the other 3 don't match and has the same mounting issue as above. Replacing all 4 doesn't seem to make $$ sense, unless it's going to turn these into $150 value cabs as a result. Of course, I could just sit and wait on an EBAY alert for one to pop up too, but they tend to be pricey when/if they do.
Thoughts?
Thoughts?
