@majick47 You keep telling him to spend $400-500 on
used system, where he specifically wrote hat he wants a (presumably working) turntable for the same amount of money.
Don't flame me for pointing this out, I get your point. And would normally agree, as the vintage electronics is so much better & reliable than new units. HOWEVER, with that being said keep in mind that even vintage, analog systems needs to be serviced & properly maintained. Heck, I've just had a Thorens TD110 here couple of months ago, for the repairs. The owner (who happens to be my next-door neighbor) asked me if I could take a look at it & sort it out since he wasn't using it over the last 20-30 years. Expecting it to be a quick job, I immediately said yes & ended up having my hands full throughout the entire week! First of all, it needed a whole new stylus. Second, the motor was all seized up, so it had to be lubed. Third, there was some sort of mechanical fault, issue with the flip switch, for the "33" speed. Fourth, there was a mechanical issue with the spring in the tonearm elevating mechanism. After fiddling with it for hours, I removed the entire thing & replaced it for another one, which added a lot more force to it. And last, fifth - it needed a whole new RCA lead! Obviously, it wasn't removable, so the entire unit had to be taken apart & desoldered. You see where I'm going with this, right? And that is ONLY just Thorens TD110 alone, without anything else. He also had a Marantz 2226B receiver, which had to be professionally cleaned. And I'm mainly referring to the contacts, potentiometers & mechanical switches, NOT dusting off the metal cabinet from outside.
So really
@Jason!978 - if you're not willing to invest time AND money into your old-school rig I would highly recommend that you go with something modern. If you are, then by all means, follow
@majick47's advice. Sometimes oldschool is the best way to go!
