I have some nice older cabinets with walnut veneer that I want to put new drivers in to make a "vintage looking" 2 way set with new drivers. I want to try some of the Jamo (Philips) drivers that are on clearance at PE and after running the numbers for an 8" woofer have decided on either JAMO 22316 or Jamo 20418. Both woofers are 8 Ohm. I don't want to put a new front baffle on or alter the external appearance of these, so I realize some compromises will be made.
I'd like to match them to JAMO 20138 1" Soft Dome Shielded Tweeter 4 Ohm. If I do this I'll need to wire in series for a 12 Ohm speaker correct (parallel calculates out to 2-3 Ohm IIRC)?
My question involving the crossover is this: I want to keep it uber simple ala EPI T/E series and just have a capacitor for the high pass. When wiring the cap into the circuit, I'd wire from the neg woofer terminal thru the cap to the pos tweeter terminal correct? If so, do I still choose the cap value based on the driver's 4 Ohms or 12 Ohm since the signal's going thru the woofer?
My other thought is to not go all Jamo and use this cone tweeter:
Pioneer FD66AP45-13F. That would keep both drivers at 8 Ohms so I could wire parallel for a 4 Ohm system. Does anyone know what the Fs of this tweeter is? The reviews seem decent and it would drop right in to the existing cutout. Would it's 93dB be too high compared to the woofer's 87dB?
Thanks for all the help,
John
John
