SET12, I don't understand the changing of inductor values with wire size. doesn't that change crossover freqs? Pls. explain. Can't I just get larger guage aircore coils of same mH values for the coils now in the xovers?
ferninando,
I'm not an expert at Inductors but George at North Creek is. I did go to school for Electronics so I do have some knowledge as to how parts work.
To answer your last question first.
Yes you can and thats exactly what I did.
Some would argue well your changing the DCR of the original coil and thats correct. And your changing the voicing and yes thats correct.
The DCR or DC resistance is added in series with the inductors AC resistance Inductance value in ohm's for a final value. It will have an influence but its nil IMO. For instance my 3mH Air Core North Creek inductor has a DC resistance of lest than .1 ohm and the stock Iron Cores maybe .5 ohms.
Assuming the that both inductors are 3mH the resistance is 13.188 ohm's at 700hz my crossover frequency. With the DCR's added the difference is 3% between them. Hardly a big deal when other network parts can have a variation of 10% individually.
So basically the DC resistance is smaller with larger coils and large for smaller coils. Iron cores can be quite small but they have their own issues.
George at North Creek believes its the DCR that perhaps makes most of the difference. For me there's just something about core size like the 28lb Single-Ended output transformers I use which have an amazing sense of foundation with music.
To be clear here, I'm an audiophile in pursuit of the best sound I can for the limited funds I have. I am not after functionality but extreme performance is what I seek.
Unfortunately High End Audio can cost in the 10's of thousands. And I'm spoiled cause I have friends that have spent this that I can not afford. So I pursue DIYing to an extreme and the North Creek stuff met my needs in spades at 1/4 of the cost I could of spent, there are others of course but North Creek has been the best bargain for me and everything he has said I certainly have heard.
But this is the biggest thing that I have heard from Iron Core Inductors is
"distortion sounds like compression - and also measures as wave-form compression."
And I agree with what he says below
From North Creek's site
What about ferrite core inductors, which have very low DCR?
The problem with ferrite core inductors - all of them - is hysteresis distortion. Hysteresis is related to the energy loss incurred by the core material during the magnetization polarity shift that occurs in every cycle of the signal flowing though the inductor wire - for a 500 Hz signal, this is 500 times the core polarity has to be reoriented, per second! Hysteresis distortion sounds like compression - and also measures as wave-form compression. Furthermore, when the current though the inductor is large enough, the core will saturate and the value of the inductor dynamically shifts to a much lower value. This is also clearly audible.
The only practical application for ferrite-core inductors in high end audio is as low DCR "trap" coils in tweeter resonance trap circuits, where the circuit is functioning in a very narrow frequency window and the current flow is extremely small.
To answer your first question.
Its really all about shape form and length of wire that is needed for a specific mH value. Inductance is inductance no matter what the gauge of the wire is.
As to the sound of specific Inductors. It in how they are made and the quality of the materials which the North Creek site goes into.
As to changing the crossover frequencies as I pointed out above the only component that can is the DCR value and as I pointed out a few percent is no big deal in my book. Especially with ultra simple networks.
Here is a nice Inductor calculator which I used to compare my own 3mH 8AWG Inductors to.
http://www.diyaudioandvideo.com/Calculator/Inductor/
Coil diameter is the inner coil diameter the length is the thickness.
I measure my coils 1.5in inner coil and 1.5in tall 8AWG wire 3mH plugged in the #'s
What I came up with is pretty close to what I have. But one can see variation when changing size cores or wire gauge and so on.
SET12
