Crossover re-Cap Questions
clang444
I re-foamed a pair of Cerwin Vega D2s and now I want to re-cap the crossovers. The current capacitors are 1 MFD and 4.7 MFD 50 V. Is it OK to use 250 V replacements? I might add that the 4.7 MFD cap is tiny, like 1/2" long.
There's also something marked CULVER 06A-50 in the crossover. From what I can tell it is a self-resetting circuit breaker. Is this correct?
The higher voltages are fine as replacements. Use at least 125volts. The higher the voltage, the bigger the cap. And I believe the Culver component is a circuit breaker.
The Culver is indeed a circuit breaker for the tweeters. My Infinity RS4b uses them too.
I recently recapped a pair of JBL L50s and my usual source for caps was out of many of the values I needed. I took a gamble on using Supertech MPT Yellow Film Capacitors that are being sold on the Big Auction site. I am very pleased with the results, so I will probably go the same route. Just about anything has to be an upgrade from the original caps.
Is that circuit breaker resettable? Or do you need to replace it once it trips?
Thanks!
It resets itself within a few seconds... my RS4b crossovers also have a thermal switch that resets after it cools down (right next to the circuit breaker in my pic), but I've never had either of them trip, the Onkyo M-508 amp I powered them with for 35 years always went into protection first.
I finally got around to re-capping the Cerwin Vega D2s with Supertech MPT Yellow Film Capacitors. What a nice improvement, the old caps must have been shot. There is more clarity in the mid-range and the sound stage is more presant. Improved detail in the sound. They also appear to be pretty efficient, as they sound louder than the speakers I am compared them to.
